Activity › Forums › Apple Final Cut Pro Legacy › uploading final cut pro quicktime commercial without losing generations
  • uploading final cut pro quicktime commercial without losing generations
    Posted by Colin Resch on May 19, 2010 at 8:07 pm
    I recently edited a 30 second commercial in final cut pro. I exported it as a quicktime with dimensions 720×480. Codecs DV/DVCPRO-NTSC. The quality is perfect upon viewing on my IMAC but when I uploaded it sendspace and opened that link, the video quality took a major hit. Looked as though it had lost 20 generations. Is there a way to export out of final cut in the highest quality and then upload it to a site without losing quality?
    CResch
    Colin Resch replied 16 years, 4 months ago 2 Members · 2 Replies
  • Doug Beal
    May 20, 2010 at 5:20 pm
    Are you trying to view it over the web? or did you download it and there was a deterioration from uploading and then downloading?
    If up/down there’s an issue it’s something they are doing
    if trying to view over the web DV/DVCpro NTSC is to high a data rate to be played over the web and will look hammered as the player tries to compensate for incomplete data
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Colin Resch
    May 20, 2010 at 5:31 pm
    Doug,
    Thanks for the reply. Actually, it isn’t for the web. This is a 30 second commercial currently airing on the versus network. I uploaded it to comcast spotlight. Also, as a test I uploaded it to sendspace and sent it to myself. In both instances, a massive loss in quality.
    CResch
