Activity › Forums › Apple Final Cut Pro Legacy › upgrading to fcp 5 studio from an earlier version
  • upgrading to fcp 5 studio from an earlier version
    Posted by Sean O’connell on May 20, 2005 at 3:36 am
    Help!
    I bought an accedemic version of 4.5 last year and found out that these versions are not elegible for upgrading to fcp5. I went out on ebay looking for a full retail version of an earlier release and found fcp2 at a reasonable cost. However, the description says it runs on OS 9 and I’m running panther. Can I buy this earlier version for the registration number alone or will i need to actually install the software. If I do need to install the software can I do so with panther and expect it to run in the “classic” mode?
    Also, if i’m going to install an earlier version should I make sure 4.5 is uninstalled from my main HD first and to disconnect my external drive with existing project files first?
    Any giudence would be appreciated. Thanks!
    Sean o
    oconnellsean@comcast.net
    Bill Davis replied 21 years, 4 months ago 4 Members · 4 Replies
  • Bob Carpenter
    May 20, 2005 at 4:05 am
    I dont believe you can upgrade from 2 to 5. I’m pretty sure you need to be upgrading from 4 or 3 at the least. Call apple and ask them.
  • Walter Biscardi
    May 20, 2005 at 9:24 am
    [bob carpenter] “I dont believe you can upgrade from 2 to 5. I’m pretty sure you need to be upgrading from 4 or 3 at the least. Call apple and ask them.”
    If it’s like it has been in the past, you can upgrade from any previous version of FCP to the latest.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Sean O’connell
    May 20, 2005 at 1:00 pm
    If I buy fcp 2 do I have to install it or just use the registration code? If I do need to install would it run in the “classic” mode in panther?
    sean oconnell
  • Bill Davis
    May 20, 2005 at 1:18 pm
    Just the registration code. Since FCP4, Apple doesn’t require the previous version of FCP to be on the drive, since newer systems won’t boot into OS 9.
    Bill
