Activity Forums Boris FX Sapphire Upgrading from DSv8 to DSv10 – Ramifications?
  • Upgrading from DSv8 to DSv10 – Ramifications?
    Posted by Jeff Winston on May 14, 2009 at 5:43 am
    In order to upgrade my Avid DSv8 to DSv10, what will I need to do to make sure my Sapphires are compatible?
    Jwinston
    Jeff Winston
    Gary Oberbrunner replied 17 years, 3 months ago 2 Members · 3 Replies
  • Gary Oberbrunner
    May 16, 2009 at 8:49 pm
    Hi Jeff; Sapphire should just continue to work if you upgrade to DS10. If you reinstall the system, you’ll need to reinstall Sapphire of course.
    — Gary
  • Jeff Winston
    May 20, 2009 at 6:31 am
    Thanks. I should have been more precise. The concern was that since we were moving to a 64 bit OS we might need to budget for an upgrade?
    Jeff Winston
  • Gary Oberbrunner
    May 21, 2009 at 12:35 pm
    Hi Jeff. As long as you have v2 (2.081, make sure you install the 64 bit version) or v3 (32 and 64 bits in the same installer) you should be OK. See https://www.genarts.com/support/sapphire/avid#ds. V1 will not work on a 64-bit OS, it’s too old.
    — Gary
