Activity Forums Apple Final Cut Pro Legacy UPGRADING EDITING DECK NEED ADVICE
  • Sean Oneil
    April 20, 2006 at 5:01 am
    Ok, first off, the Y/C from the Radeon card is not a broadcast output. Far from it.
    As for capturing, many people say that letting the deck do the 4:2:2 conversion is better than capturing Firewire. However, it has been demonstrated that if you capture Firewire and apply the 4:1:1 chroma smoothing filter, you can achieve the same quality as you would SDI capture.
    As for what VTR to get, I’d reccomend wating a short while for these models to start shipping:
    https://www.promax.com/Products/Detail/600000
    Sean
  • Swanny4life
    April 20, 2006 at 6:38 am
    So the deck is compatabile with standard DVCAM tapes too?
    As far as the Broadcast Monitor, Do I need a Capture Card to send a reliable signal and with this new deck will I need a HD card?
    Tom
    Tom Swan
    In The House Productions, Inc.
    Philadelphia, PA
  • Sean Oneil
    April 21, 2006 at 6:39 pm
    Yes it works with full-size DVCam tapes. No card needed. It’s a firewire deck. Don’t buy it on my advice. I don’t own one (nobody does since it’s not out yet). Do your own research and look into it.
    Sean
