Activity Forums Avid Media Composer Upgraded to MC 6, now media is offline & won’t relink, also missing codecs
  • Upgraded to MC 6, now media is offline & won’t relink, also missing codecs
    Posted by Mike Halper on November 17, 2011 at 2:59 pm
    I just finished resetting up my computer and installing Media Composer 6. I was running MC 5.5.3 before. Did a clean install of the entire system and have Lion 10.7.2 installed. Opened up the 5.5.3 project in MC 6 and now a lot of random media is offline. I tried relinking but it doesn’t find the clips. All my media is on a non-system drive that wasn’t touched.
    These clips were all transcoded to DNxHD 115. If I go to batch capture the offline clips or even to reimport them I’m given only 3 options for codecs: DNxHD 444 350 X MXF, 1:1 10b RGB MXF, Apple ProRes 4444 MXF. These codecs are overkill for the media I’m working with, AVCHD 8-bit 1080p. Does anyone have any idea what’s going on here? I did install the AvidCodecsLE and AvidCodecsPE, as well as the AMA plugin for AVCHD.
    I also trashed the pmr and mdb files. Restarted computer. Started MC 6 and it spent some time scanning the drive. Media is still offline and I still have only those 3 codecs showing as import options.
    How can I get the media to relink and get the rest of the codecs to show in the import settings?
    _______________________________________________
    Mike
    Mike Halper replied 14 years, 8 months ago 2 Members · 4 Replies
  • Mike Halper
    November 17, 2011 at 3:06 pm
    Also, under Media Creation settings, the only resolution option is ProRes 4444 MXF. This is with the existing project on a new project.
    Mike
  • Mike Halper
    November 17, 2011 at 3:52 pm
    All problems solved. Nevermind.
    Mike
  • Andrew Mckee
    November 17, 2011 at 4:04 pm
    What was the issue? Has the color space changed from 601/701 to RGB?
    Andrew McKee
    Editor/Colourist
    Avid Certified Instructor – MC5.5
    Apple Certified Trainer – FCP7
    Pixelwizard.net
  • Mike Halper
    November 17, 2011 at 4:12 pm
    Yes. I don’t know how either. Maybe something that happened from opening 5.5.3 project in 6.0.
    Mike
