Activity › Forums › Adobe After Effects › Upgraded to Mavericks and the Dynamaic Link between Adobe After Effects & Premiere will not work.
  • Upgraded to Mavericks and the Dynamaic Link between Adobe After Effects & Premiere will not work.
    Posted by Jonathan Haloossim on January 18, 2014 at 9:28 pm
    Hey,
    I got bought a 2008 Mac Pro, which was running on Mavericks, then I updated my 2010 Macbook Pro to Mavericks so I could use Migration assistant. I use Adobe CS5. Now, the Dynamic Link between After Effects and Premiere Pro doesn’t work. Individually I can use either program, but when when I try click “edit original” in my Premiere timeline to go to After Effects it will bring up After Effects, but not load the file or freeze then just close the program. I don’t think this a Migration Assistant issue, because it’s an issue on both my computers.
    For awhile After Effects would give me this error message when trying to use the Dynamic Link – “Unable to execute script at line 36. After Effects error: Can’t overwite file “/Users/Library/Preferences/Adobe/After Effects/10.0/Adobe After Effects 10.0-x64 Prefs”. It hasn’t shown that error message in a few days. Couldn’t figure it out.
    Does anyone know how to fix this issue?
    Computer Specs
    Mac Pro 2008
    Software OS X 10.9.1 (13B42)
    Processor – 2 x 2.8 GHz Quad-Core Intel Xeon
    Memory – 8 GB 800 MHz DDR2 FB-DIMM
    Graphics – ATI Radeon HD 5770 1024 MB
    Hard Drive – 2 x 1TB
    Macbook Pro Mid 2010
    Processor – 2.53GHZ Intel Core i5
    Memory – 8 GB 1067 MHz DDR3
    Graphics – NVIDIA GeForce GT 330M 256 MB
    Hard Drive – 500GB
    Harold Parker replied 12 years, 6 months ago 4 Members · 5 Replies
  • Todd Kopriva
    January 19, 2014 at 5:59 pm
    Mac OS has incorrectly set the permissions for some files.
    When you upgrade a Mac OS (as opposed to installing the new version fresh), Mac OS will _often_ set permissions of folders and files incorrectly.
    You’ll see this problem in programs like After Effects in the form of error messages saying that a file can’t be written, overwritten, or renamed.
    To fix this in the case of After Effects, go to the preferences folder and set the _entire_ preferences folder ( /Library/Preferences/Adobe/After Effects/10.0/ ) and all of its contents to be writable, not read-only.
    After Effects team blog
  • Jonathan Haloossim
    January 19, 2014 at 10:27 pm
    Such a simple fix!!! Thank you so much!!!
  • Jim
    January 21, 2014 at 1:16 am
    Todd,
    I am also running into linking issues PR & AE CS6 OS 10.9.1.
    I’ve looked into Library/Preferences, but don’t see an Adobe folder.
    I sure would appreciate a bit more guidance.
    Jim
  • Jim
    January 21, 2014 at 2:15 pm
    Todd,
    I did finally find the correct Library (user, not the HD). Ultimately, went back to basics and repaired permissions, and all seems to be OK.
    Sometimes it’s the simple things:-)
    Jim
  • Harold Parker
    March 31, 2014 at 11:08 pm
    I’m still having issues giving the proper permissions to my AE after upgrade to Maverick. Every post tells you to go to this directory which doesn’t exist on my machine. Users, Name/library/preferences/Adobe After Effects. On Maverick 10.9.2, I don’t have a library folder in the Users folder. Please help!!
