Activity › Forums › Adobe Premiere Pro › Upgraded to CS 5.5 (Windows) now effects are a mess
  • Upgraded to CS 5.5 (Windows) now effects are a mess
    Posted by Craig Carlen on March 15, 2012 at 3:15 am
    Well I shouldn’t say they’re a mess, but they’re acting funny. Effects are working – until I enable key frames. If I just use an effect in it’s static form – the effect is fine. I can change any/all parameters and the effect will work. But the minute I enable any key frames to change parameters over time the effect in question will cease to work. And it’s any effect – from a basic Gaussian blur that shipped with CS 5.5 to one of my Red Giant effects.
    Any ideas on what’s going on? This didn’t happen with CS 5.
    Craig Carlen replied 14 years, 6 months ago 3 Members · 5 Replies
  • Bob Dix
    March 15, 2012 at 6:53 am
    Get the upgrade to CS5.5.2
    Freelance Imaging & Video
    AUSTRALIA
  • Jeff Pulera
    March 15, 2012 at 1:50 pm
    5.5.2 update can be downloaded here – https://www.adobe.com/support/downloads/product.jsp?product=98&platform=Win
    Be sure to choose either boxed or electronic to match your product. I have better luck with the downloads than the auto update business.
    Jeff Pulera
    Safe Harbor Computers
  • Craig Carlen
    March 20, 2012 at 5:52 pm
    Sorry for the delay – had some out-of-town things that needed my attention.
    So I never thought to check for a upgrade – downloaded the upgrade (boxed) and installed it. Didn’t fix the problem. Even went so far as to uninstall all my third party effects and re-install them – no joy.
    Any other options before I revert to CS5.0?
  • Jeff Pulera
    March 20, 2012 at 5:59 pm
    Hi Craig,
    Sometimes installs go bad, or get corrupted after the fact. In any case, this is not a common issue so I would not give up on CS5.5.
    Rather, uninstall, run the Adobe Cleaner Utility, and reinstall CS5.5 and that should make it right. Be sure to use Help > Deactivate before uninstalling.
    Here is the Cleaner, very important to run this – https://www.adobe.com/support/contact/cscleanertool.html
    It could be that you didn’t fully uninstall CS5 before installing CS5.5, or not running the Cleaner, that resulted in a bad CS5.5 install.
    Jeff Pulera
    Safe Harbor
  • Craig Carlen
    March 20, 2012 at 6:42 pm
    I need to amend my initial statement as well – effects keyframes do work – unless the video clip in question is a .mov formatted file with alpha channel (animation). Seems to work fine with mpeg, mp4, and/or avi. But no joy on any .mov file I have that I’ve preserved the alpha channel (basically AE animations) regardless of bitrate and resolution.
