Activity › Forums › Apple Final Cut Pro › Upgraded system drive to SSD, now FCPX won’t properly open Library
Posted by Dustin Bowser on January 28, 2014 at 12:17 amI put an SSD in one of the other slots and did a fresh install of Mavericks and FCPX 10.1, and now my Library, which lives on another drive won’t properly open.
At first when I tried to load it, it won’t crash FCPX each time while loading. I went into the library and deleted the current version.Flexolibrary, and that allowed FCPX to open, but now I see that my files are offline, and when loading a project it hangs on the “Loading Project into Timeline” dialogue and just stays there. It doesn’t let me into the project and I have to force quit.
Don Smith replied 12 years, 8 months ago 6 Members · 31 Replies -
Dustin Bowser
January 28, 2014 at 12:35 amRegarding the offline media — When I attempt to relink files, in the Relink dialogue, I don’t know how I’m supposed to connect back up to the media inside the Library. The Finder dialogue that comes up doesn’t allow me to go inside the Library itself, so it just says it can’t find the media, even thought I know it’s in the there.
I also can’t find in 10.1 where the “Modify Event Reference” dialogue is, which used to be in the Inspector in the Project View, so I can attempt that as well.
I’m excited to actually start editing one of these days, after the several days of wasted media management time…
Charlie Austin
January 28, 2014 at 1:10 am[Dustin Bowser] “The Finder dialogue that comes up doesn’t allow me to go inside the Library itself, so it just says it can’t find the media, even thought I know it’s in the there.”
Go into the Library package and make an Alias of your “Original Media” folder on the desktop or wherever. You should then be able to navigate to it in the relink dialog…
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Dustin Bowser
January 28, 2014 at 1:26 amWhat can I do to get past the “Loading Project into Timeline Dialogue”? I can’t even get into my project.
Dustin Bowser
January 28, 2014 at 1:37 amIt seems that every project in this library is showing up with media offline, and just beach balls when I try to load it.
It’ is many projects.
Is there any way to just have all of the databases rebuilt for the events and the projects that things will relink within the library. What’s crazy is that all of the media is packaged up nicely in the library with it, so why I’m having this issue I don’t understand..
Jeremy Garchow
January 28, 2014 at 2:16 amPerhaps it’s a permissions issue?
Can you drag a library from that drive to another?
Can you drag anything else to the Mavericks drive?
Dustin Bowser
January 28, 2014 at 2:19 amThe Library is 1.6 TB. I can drag files back and forth between the drives in the finder if that’s what you mean.
Dustin Bowser
January 28, 2014 at 2:30 amThis whole project is a complete mess now, with certain things linked every which way. What would be the best way to completely start over, leaving the Events just as they are, but linking to the Original Media in a NOT managed FOOTAGE folder, and have the Optimized Media and Proxy Media inside the managed folder, and then have all of the projects relink freshly back to these events?
There are many events, and many projects, so I’m hoping there is a way to kind of do this in one foul swoop rather than project by project.
I’m just looking for a way to get freshly back to a place where I can work. I’ve wasted two whole days on this media management insanity, and with a quickly approaching deadline this is making me more frustrated with this program than ever.
Dustin Bowser
January 28, 2014 at 2:43 amAlso what’s interesting, some of the clips that are offline, if I go to the info Tab in the inspector, it says that the Original, Optimized, and Proxy media are all available, and if I click the Reveal in Finder button, it will pull up the clip in the finder, but in FCPX it’s giving me a red “Missing Files’ Image, but it doesn’t say Missing File or Missing Proxy, it’s just the Red Image.
Also in case it’s of relevance, a lot of the clips have CoreMelt Lock & Load applied to them. I’ve tried both having the plugin installed, and uninstalling it to see if that was the issue, but it isn’t acting right either way.
Jeremy Garchow
January 28, 2014 at 2:44 am[Dustin Bowser] “This whole project is a complete mess now, with certain things linked every which way. “
Meaning some things re linked others aren’t?
[Dustin Bowser] “What would be the best way to completely start over, leaving the Events just as they are, but linking to the Original Media in a NOT managed FOOTAGE folder, and have the Optimized Media and Proxy Media inside the managed folder, and then have all of the projects relink freshly back to these events?”
First, Optimized and Proxy media are always in the Library. Why do you need Original, Optimized,AND Proxy?
Next, what is your source footage?
Was this project started in 10.1 or 10.0? Did everything work before the SSD upgrade?
Jeremy
Charlie Austin
January 28, 2014 at 2:45 am[Jeremy Garchow] “Was this project started in 10.1 or 10.0? Did everything work before the SSD upgrade?”
Also, do you have a backup of the Library from before you did this:
[Dustin Bowser] “I went into the library and deleted the current version.Flexolibrary,”————————————————————-
