Activity › Forums › Apple Final Cut Pro Legacy › Upgrade to Studio from earlier versions of FCP?
Richard Scott replied 21 years, 5 months ago 5 Members · 11 Replies
Richard Scott
April 18, 2005 at 1:00 pm[Peter Corbett] “Thanks Richard. Did you find the workflow fluid and effective in long-form editing with FCP? Although I’m very happy with Premiere Pro’s plugin structure and integration with other Adobe apps, the ease of use (ala edit) is lacking.”
It would depend upon the specific project. If you were doing a long form with just some color correction and maybe a few lower third supers then FCP is at least as good (in my experience/opinion) as Avid and, in some ways even better than Smoke and Editbox because both of those systems (at least the versions I use) need to render before it can be played back.
If you have a lot of film dirt and tape dropout to paint out then you might find yourself wishing for an Editbox but otherwise I am pretty impressed with FCP.
As for integration with After Effects, I would suggest purchasing Automatic Duck’s pro import. The integration is seemless and well worth the money.
