Activity Forums Apple Final Cut Pro Legacy Upgrade to Final Cut Pro 5.0 Necessary for Best HD quality Video Output?
  • Upgrade to Final Cut Pro 5.0 Necessary for Best HD quality Video Output?
    Posted by Jmcgee on August 10, 2005 at 5:35 pm
    My group needs to achieve an output to Dell W3000 LCD Monitor of an HDTV resolution of 1920 x 080i at around 25-50MBps. The data–a .mov file compressed as MPEG-2 using Final Cut ProHD (4.5)’s “Compressor” utility, needs to be High Defintion! We need to match the resolution while maximizing data rate, and minimizing compressing loss.
    While this method will give us decent results, I was wondering if there is any reliable information on Final Cut Pro 5.0’s “Compressor 2.0” utility to do a better job with MPEG-2 compression. Will upgrading to Final Cut Pro 5.0 be worth it!?!?!
    v/r
    Jack R Mcgee
    Jack R McGee
    3373037299
    Astrophysics Theory Group
    Dept. of Physics & Astronomy
    Louisiana State University
    Jmcgee replied 21 years ago 2 Members · 2 Replies
  • Jerry Hofmann
    August 11, 2005 at 1:53 pm
    Well, I can say that Compressor was completely redone for FCP 5, so without really ever testing it here, can’t say that it would be a lot better… I’d think that FCP 5 though, running in tiger brings a lot of other benefits, multicam, better quality renders etc…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jmcgee
    August 11, 2005 at 3:36 pm
    Thanks Jerry. It seems that this technology is just too new for anyone to have put every scenario through the “ringer”
    Jack R McGee
    3373037299
