Activity › Forums › Apple Final Cut Pro Legacy › upgrade question
  • upgrade question
    Posted by Ben Oliver on August 9, 2005 at 9:11 pm
    hey all, i am running a dual 1.8 g5, and i want to upgrade to uncompressed editing.
    what card, and hard drive arrays would you suggest??????? what would be the least expensive?
    Shane Ross replied 21 years, 1 month ago 3 Members · 2 Replies
  • Walter Biscardi
    August 9, 2005 at 9:46 pm
    My standard answer is the Kona 2 with a set of Medea FCR2X Fibre Channel drives. You can do a search on this forum on capture cards, upgrades, etc…. and you’ll find a lot of discussions about this.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Shane Ross
    August 9, 2005 at 10:59 pm
    Uncompressed SD? HD?
    If HD, and even if SD, Walter’s suggestion is a good one. But if you are only doing SD, you can get an AJA I/O or Decklink Extreme card, and then get a nice External SATA Array from either Big Disk or FirmTek.
