Activity Forums Zaxwerks Updating an Illustrator File
  • Updating an Illustrator File
    Posted by Ray Lane on July 29, 2005 at 2:57 pm
    Greetings,
    This is probably a dumb question with a simple answer, but…..
    I have an illustrator logo that was used to create a 3D anim in Invigorator. Now the customer has changed the Illustrator logo slightly. How do I update the illustrator file in Invigorator without having to redo all the textures, animation, etc.
    Serge Hamad replied 21 years ago 2 Members · 1 Reply
  • Serge Hamad
    July 29, 2005 at 5:10 pm
    In the Set-Up window when you click on the “Object” tab you will see two options: “Reload” & “Replace”.
    -Reload will only work if you checked the “Open as layers” option when importing your ai file into Invigorator. In case you did so and your client worked on an existing layer then simply select your object/layer in the Set-Up window and click the reload button. The position of your manipulated layer in Illustrator must be the same then the old layer to avoid any offset.
    -In case you imported your Illustrator file as a single object then select your object in the Set-Up window and click “Replace”
    If you have more questions let us know.
    Salut.
    Serge
