Activity Forums VEGAS Pro Updated Newblue fx taking 4x longer to render
  • Updated Newblue fx taking 4x longer to render
    Posted by Jeff Schroeder on July 18, 2012 at 2:05 pm
    Good morning all,
    Has anyone noticed a performance hit using updated newblue effects? I upgraded to the GPU versions of Video Essentials 1 through 4 about a month ago, and performance has been terrible. Newblue tech support is looking into this. Has anyone had experience with their tech support?
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
    Edward Troxel replied 14 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
  • Edward Troxel
    July 18, 2012 at 6:17 pm
    What’s the timing difference with GPU Acceleration turned on vs turned off?
    What video card/driver version?
    Edward Troxel
    JETDV Scripts
  • Jeff Schroeder
    July 18, 2012 at 9:16 pm
    Thanks for responding Ed,
    I have only run in CPU mode. My system has 12 real cores (+12 hyper-threaded.) Early tests indicated that GPU mode was a hindrance. I have re-enabled it to re-visit that question.
    My NVIDIA driver version is 301.42.
    Jeff
  • Edward Troxel
    July 19, 2012 at 1:12 pm
    If you have the 3.0 version of the NewBlue plugin installed, I was referring to having GPU both turned on and off there.
    That driver is sufficiently up to date.
    Edward Troxel
    JETDV Scripts
  • Jeff Schroeder
    July 23, 2012 at 5:05 pm
    I’m not sure I follow you Ed. I have reverted to Video Essentials 1.4, because I have to get work done.
    Where in the plugin do you change the GPU setting?
    Jeff
  • Edward Troxel
    July 24, 2012 at 2:47 pm
    Version 1.4 does not have GPU Acceleration. I did not realize you had gone back to the previous version. That option would only be in version 3.0.
    Edward Troxel
    JETDV Scripts
  • Jeff Schroeder
    July 24, 2012 at 3:00 pm
    Ed,
    I’m in a real situation here. After backing out of the NB upgrade my render times are still 4x longer. I have started a support ticket with NB but it’s not getting a lot of traction.
    I have gone to batch rendering the noise reduction part over the weekend for the shows I edit the following week. Fortunately it’s not time sensitive content.
    I wish I could get my old system back.
    Jeff
  • Edward Troxel
    July 24, 2012 at 5:50 pm
    Put another note on the ticket at NewBlue.
    Edward Troxel
    JETDV Scripts
