Updated from R13 to R17 and a bit lost on a few things
There are some notable differences between the two version and there are a few things that i am unsure on how to set as i never needed to do them in R13.
Firstly, how do i get model mode to display vertices. In R13 clicking on a object in model mode would also display its verts and in R17 there are no verts bar the outer edges. This is especially annoying when i want to click on a nurbs object to see the difference in verts between the object inside the nurb and the nurb itself.
Secondly, in R13 the workplane was a square, in R17 the workplane stretches off into infinity. How do i reset the size of it so that it doesn’t vanish into the distance anymore?
Thirdly, is there any way in R17 to make Z the up axis?
