  • Posted by Tony West on January 17, 2014 at 1:55 pm
    I have not had anymore lag problems since I copied my library to another drive and started working off it.
    That’s the only thing I did different and not one beach ball since (I also turned off that App nap).
    Still not sure why the one project could not play from there but I have to conclude that particular problem was with my equipment and not with the 10.1 update.
    Well, I started a post going off so I wanted to update you guys.
    Thanks for the help everyone offered.
    Mitch Ives replied 12 years, 8 months ago 11 Members · 31 Replies
  • 31 Replies
  • Jeremy Garchow
    January 17, 2014 at 2:47 pm
    Thanks for the update, Tony.
    What kind of a drive was it?
  • Tony West
    January 17, 2014 at 3:01 pm
    It’s a G-Tech drive.
    Using the FW-800
    I have had it for maybe a year and half I think.
  • Jeremy Garchow
    January 17, 2014 at 3:15 pm
    Are you using an Apple Thunderbolt adapter?
  • Eric Santiago
    January 17, 2014 at 3:18 pm
  • Tony West
    January 17, 2014 at 4:33 pm
    [Jeremy Garchow] “Are you using an Apple Thunderbolt adapter?
    No I’m not
  • Tony West
    January 17, 2014 at 4:34 pm
    [Eric Santiago] “Have you upgraded to 10.1.1 yet?”
    No, not yet
  • Douglas K. dempsey
    January 17, 2014 at 4:51 pm
    Why? Does the Tbolt to FW adapter cause any known issues?
    Doug D
  • Jeremy Garchow
    January 17, 2014 at 5:34 pm
    I find the Apple adapter to be a little slow.
    I have a Belkin TBolt dock coming and I am going to compare the speed of that fw800 vs the Apple fw800.
    Although, for mobile work, usb3 is probably going to become more normal for me.
    I was doing transfers at 133 MB/sec the other day and USB3 seems to be rather ubiquitous.
    Jeremy
    January 17, 2014 at 5:58 pm
    Thanks, Jeremy. And this discussion is not even OT, as using FCPX inevitably pushes you to modern Macs with Thunderbolt, even though you may have a dozen FW drives on the shelf, full of footage!
    Re: USB 3, I was told the one downside was the fact that it’s not full duplex, so while great for a read OR write, less than perfect for constant read/write that happens during editing.
    This is something I don’t entirely understand. If you have projects, events AND media on same external, maybe an issue. But if your external is simply for original/optimized media, isn’t that read-only? Does location of your render files completely alter the equation, since they are being written while simultaneously reading original media?
    I am assuming a single FCPX user, external drive with media. Where do you keep projects/events library, relative to original or optimized media?
    Doug D
  • Willy Pimentel
    January 17, 2014 at 6:14 pm
    We have four drives unusable.. Two were repaired and returned. I just gave up
    Willy Pimentel
    Motion Graphics Editor/VIz Artist/Trio/Camera Director – Univision NY
    Macbook Pro 2011 thunderbolt/ TBolt Display/ 2 SSD Hds /Lacie Tbolt
Page 1 of 4
