Activity › Forums › AJA Video Systems › upconverting 525i29.97 to 1080psf23.98…frame blending issues
Posted by Sithcommander on June 8, 2005 at 11:49 pmWe have upconverted from miniDV (Canon XL2) 23.98p with 2:3 pulldown (source setting in Kona control as 525i29.97) to 1080psf23.98.
Kona control panel source setting: 525i29.97
FCP Capture preset: 1080psf23.98
*FCP Capture preset custom input setting: 1080i29.97We are experiencing some stuttering or what could be frame-blending issues. Any advice?
Is it better to achieve the 29.97 to 23.98 conversion in CinemaTools (reverse telecine) ?
Jerry Hofmann replied 21 years, 3 months ago 5 Members · 6 Replies -
Jerry Hofmann
June 9, 2005 at 2:54 amI’d certainly experiment with CT’s conversion… that way it’s frame for frame right? then convert in software…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Ned Soltz
June 9, 2005 at 3:43 amI would definitely not capture at a 23.98 setting. I think you are correct in removing the pulldown in Cinema Tools. Then, of course, edit in FCP in a 23.98 timeline.
Ned Soltz
Keicol
June 9, 2005 at 6:01 amI have a 23.976 project shot at 1080psf 8 bit using an F900, I also have an additional camera, Sony Z1 HDV which I’m shooting at HDV 25i, how can I get this footage into my project?
I had planned on using the Y Pb Pr into an AJA HD SDI analog HD to HD SDI converter which I bought to get the footage into my F500 using the 25i frame rate and then reset the F500 to playback as a 23.98 tape. I haven’t tried it yet and have heard that I needed the 3:2 pulldown option board which I don’t have installed.
Is there a software way to achieve this?
The Z1 is a handy third camera I was hoping to use for is small size for quick action inserts.
thanks, Keith Collea
Gary Adcock
June 9, 2005 at 1:09 pm[keicol] “I also have an additional camera, Sony Z1 HDV which I’m shooting at HDV 25i, how can I get this footage into my project?”
I capture HD component direct from the camera (using the FW connection for deck control) with the AJA HD10AC component to SDI converter direct via my Kona2 card.
Then I do not have to deal with the added layer of issues inherent when laying off an “off speed” format 25fps to a tape with a different frame rate 23.98 – I think this is just asking for more problems than you have already had. Slip the timebase in FCP / CT without having to deal with the pulldown removal at all.gary adcock
Studio37
HD and Film Consultation -
Jerry Hofmann
June 10, 2005 at 3:19 pmThat too would be an excellent workflow Gary… I’ve seen that DA do wonderful things to HDV material too. HDV is a rendering time hog… I”m hearing of extremely scary conversion times to MPEG-2 with it… really scary… HD takes a ton less time to down convert to SD DVD’s…and looks spectacular… (but I digress..)
Jerry
