Activity Forums Broadcasting upconvert ntsc dftc to 23.98psf frame accurately?
  • upconvert ntsc dftc to 23.98psf frame accurately?
    Posted by Kurt Outwater on April 28, 2012 at 12:27 am
    I’m trying to accomplish this with a panasonic ufc-1800. Is it possible to do this? With NDFTC there seems to be no issue but there is a TC offset when using dftc from the master tape. I’m taking the pulldown out of the ntsc master as well.
    Any thoughts would be greatly appreciated!
    John Heagy replied 14 years, 4 months ago 2 Members · 3 Replies
  • John Heagy
    May 1, 2012 at 3:25 am
    If you start the conversion on an even second the two should match. Otherwise it will be offset but should not drift.
  • Kurt Outwater
    May 1, 2012 at 6:01 am
    it’s a two step process with the ufc…. convert with an edit dub to ndftc then do the conversion.
  • John Heagy
    May 3, 2012 at 9:05 pm
    Oh I see now. There is no such thing as ndtc 23.98 so it will be impossible for it to match your dftc 60i master.
