Activity › Forums › Panasonic Cameras › Upconversion with Panasonic 1200A
Posted by Todd Drezner on November 19, 2006 at 6:58 pmDoes anyone know the menu settings to use on the Panasonic 1200A when upconverting DV to DVCPro HD? I thought I had it correct, but when I try to capture I get a message that there is no video. Any advice would be appreciated. Thanks,
Todd
John Sharaf replied 19 years, 10 months ago 3 Members · 8 Replies -
John Sharaf
November 19, 2006 at 7:37 pmTodd,
I believe that you cannot capture directly thru the 1200A, but must play the DV material through the firewire into the deck and record it onto a tape, then you can playback that tape either through the FW or HD-SDI and a capture card to import to FCP.
JS
John Sharaf
November 19, 2006 at 7:52 pmTodd,
You only need a capture card if you want to output from the HD-SDI spiget on the deck, you can also import to FCP viw FW, just use the appropriate “east Setup”. In general, I’ve had more reliable capture with my Kona Lhe card that with the firewire, but this is a very subjective oppinion!
JS
Todd Drezner
November 19, 2006 at 8:31 pmJohn,
I’ve been trying to capture over FW. As far as I can tell, all menu settings are correct, but I continue to get an error message that there is no video. My easy setup is DVCProHD 720p24. I’ll review the menu settings again — must be something in there. Thanks very much for your help.
Todd
John Sharaf
November 19, 2006 at 10:29 pmTodd,
Let’s check the following:
#600 VIDEO IN SEL must change from default to 0002 (1394 setting)
#880 DIF SPEED must change from default to S100Let’s see if this works!
JS
Todd Drezner
November 20, 2006 at 1:07 amI’ve left the office where the deck is, but I’ll try tomorrow and let you know. I know 600 was set to 1394. Not sure about the other. Thanks.
Todd
Chris Bell
November 20, 2006 at 6:25 amNo upconversion is possible via firewire. Only HD-SDI.
Chris Bell
John Sharaf
November 20, 2006 at 3:15 pmYeah, it’s coming back to me now; the workflow for what you want to do is either upconvert by playinmg your DV tape in the 1200A and capturing out the HD-SDI spiget into a capture card, like a Kona or else use two 1200A’s, one to play back and the other to record the HD-SDI output, then you can play back the upconverted tape through FW into FCP.
Sorry for the lapse and thank you Chris Bell!
JS
