Activity Forums Adobe Encore DVD Up the Blu-Ray Creek
  • Up the Blu-Ray Creek
    Posted by Warren Gentry on September 13, 2007 at 11:01 am
    I think I’m up the blu-ray creek without a paddle. I bought a blu-Ray burner from FastMac and installed in my my non-Intel G-5 Mac. I bought Adobe Encore CS3 which only works on my Intel Macbook Pro. I bought Toast 8 which I installed on the same Mac as the blu-ray burner.
    So I author a blu-ray disc in Encore and output it as a Blu-Ray disc image. I then switch the drive over to the non-intel Mac and use Toast 8 to burn the disc using the VIDEO TS interface much like I would do for a standard DVD to a BD-R disc. I bought the Samsung BD-P 1000 player which claims to play BD-R discs. It does not play.
    My question is: Can you burn a blu-ray disc image as a data disc or in the Video-TS interface of Toast 8 and expect it to play anywhere?
    Thanks for any tips.
    Warren Gentry
    Walter Biscardi replied 18 years, 11 months ago 4 Members · 3 Replies
  • Aaron Stewart
    September 19, 2007 at 7:17 pm
    Welcome to the roaring river of Bluray.
  • Joe Bowden
    September 19, 2007 at 8:54 pm
    Blu-ray does not use a VIDEO_TS folder at all in its file structure, so what you are doing will never work.
    Instead, build a BD image, and then burn from the BD image using an application that supports burning BD images directly.
    On Windows, ImgBurn can do this. Don’t know if there’s a similar application for the Mac (although I thought the latest version of Toast did – check their Help to be sure).
  • Walter Biscardi
    September 20, 2007 at 5:48 pm
    [Joe Bowden] “On Windows, ImgBurn can do this. Don’t know if there’s a similar application for the Mac (although I thought the latest version of Toast did – check their Help to be sure).”
    Toast supports the same thing
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
