Activity Forums Adobe After Effects Unwrapping a globe?
  • Unwrapping a globe?
    Posted by Luke Luxor on July 27, 2015 at 9:00 pm
    Hello all!
    I am trying to pull off an effect where I have a sphereized map of the world (using CC Sphere) unwrap to go back to a flat map of the world, but I can’t seem to find any way to do it within my budget (3rd party tools like Boris FX are a little pricey), is there ANY way at all to pull it off just within AE, and if not I will take the next best solution.
    Thanks in advance!
    Luke Luxor replied 11 years, 1 month ago 2 Members · 5 Replies
  • Kalleheikki Kannisto
    July 28, 2015 at 3:11 pm
    Use the Optics Compensation effect instead of CC Sphere.
  • Luke Luxor
    July 30, 2015 at 2:00 pm
    Alright! Let me give that a shot!
  • Luke Luxor
    August 4, 2015 at 7:04 am
    After playing with it and looking around for a while, this isn’t quite the effect I’m looking for, I might be missing something though, is there a tutorial or something you can point me to?
    August 5, 2015 at 7:26 am
    Hi Luke,
    I don’t know if there are any tutorials for the optics compensation method. It just came to mind trying to think of any built-in effects that could be used.
    The next relatively good option for creating a spherical warp with built-in tools is mesh warp (plus a circular track matte to make it appear perfect).
    A more complex option is to use an animated displacement map (at 16 bits), but it would take me hours to figure out exactly how that would be set up.
    I also tried the method of enlarging the CC sphere radius while decreasing the map size — it ends up looking essentially the same as optics compensation, but is more difficult to do. And it doesn’t go all the way to a flat map.
    In any case, I believe the key is to come up with of a good way to animate a plane wrapping into a sphere rather than the other way around. There are several ways to do this, not sure what is the best for you.
  • Luke Luxor
    August 9, 2015 at 10:01 am
    I think that is actually a really good idea, I’ll poke around to see if I can come up with any solutions!
