Activity Forums Adobe After Effects Unwrapped sphere style animation
  • Kalleheikki Kannisto
    July 31, 2016 at 3:16 pm
    You could achieve something similar along these lines. First three steps don’t require AE and you might just want to make an illustrator document that has one half of it and flip it for the other side. Add rotation, mesh warp and twirl in AE. The two halves need to rotate mirrored (one clockwise, the other counter-clockwise). This is a photoshop quick concept, it would look better with a larger twirl radius.
  • Don Johnson
    August 1, 2016 at 5:27 am
    Thanks Kalle, an interesting approach. I was hoping however that I could implement it on a non graphic image, any ideas there? In my mind it is sort of like a sphere with an image projected upon it, that has been unwrapped so that the two poles are next to one another rather than above/below.
    August 1, 2016 at 6:32 am
    You might need something like Mettle Skybox for proper conversions. What kind of an image do you have as a starting point?
