Activity Forums Maxon Cinema 4D Unwrap and Relax Problem with C4D (Video recording of problem included)
  • Adam Trachtenberg
    January 31, 2017 at 5:57 pm
    I think the first thing you’ll need to do is apply Shrink Wrap projection to the selected UV polys. That will insure that all the islands that are supposed to be connected are connected. You may also need to do this in a couple operations instead of all at once, but I’m not sure about that.
    You also may want to explore the UV Peeler function for cylindrical objects like this.
  • Ivan Viduljevic
    January 31, 2017 at 6:21 pm
    Adam, Shrink Wrap projection did the job .. i 1 Import object 2 Paint setup wizard 3 Shrink Wrap projection 4 Clear UV 5 Slectd polzgons and edgers for cut 6 Relax UV .. And it worked!
    Ty for help and thanks to CC Community.
