Activity Forums Avid Media Composer Unwrap a DNxHD Quicktime and rewrap it as MXF?
  • Unwrap a DNxHD Quicktime and rewrap it as MXF?
    Posted by Adam Recht on September 13, 2008 at 3:17 pm
    Hi
    Camera department wants to deliver me DNxHD-encoded footage in a Quicktime wrapper. I can import this into MC 3.0 no problem, but it’s sloooow – about 2.5x real time. One bit of oddness is that on import I’m presented with a dialogue box asking if I want to import the quicktime with a matte or as an A/V clip – which is odd as it’s only 24-bit data, there’s no alpha.
    Since the contents of the quicktime are already encoded with the DNxHD codec you’d think there might be a fast way of ingesting the footage – strip off the Quicktime wrapper, add an MXF one (I’m sure it’s not as simple as I make it sound) and bung the result in the Avid Mediafiles folder.
    Does anyone have any ideas that might help? Or am I just stuck with a sloow import?
    Many thanks in advance
    Adam
    Dave Schweitzer replied 17 years, 11 months ago 2 Members · 1 Reply
  • Dave Schweitzer
    September 15, 2008 at 9:11 pm
    Check your import settings, and try ignoring the alpha (as opposed to use existing or invert). This may allow you to skip the selection hurdle and at least do a batch import overnight or when the system’s not otherwise in use…
