Activity › Forums › Adobe Premiere Pro › Unwanted “Low resolution”-effect on diagonal edges when encoding H.264
Johan Andreasson replied 10 years, 8 months ago 2 Members · 16 Replies
Johan Andreasson
January 11, 2016 at 7:25 pmOk, it seems very weird if that was not set to OFF when I was rendering the first time. But did another render now on the source file from AE and then converted to h.264 in Encoder and that file looks GREAT.
Still weird cause when I check the render Que in AE and the settings used when exporting the upper field mov files it says Feld render “OFF”. So I don’t quite understand.
The only difference is that that render was don’t on my other computer at home. Well, thank you VERY much…!
~ Johan -
Vince Becquiot
January 11, 2016 at 7:29 pmIf that happens again, you can always interpret the footage is Premiere and set it to progressive.
Glad you sorted it out!
Vince Becquiot
San Francisco Bay Area
Johan Andreasson
January 11, 2016 at 7:31 pmIs that right? That’s great cause I have 12 clips and it’s the same problem o all of them.
So I don’t have to re-export the source file from AE? Just interpret them?Thanks
~ Johan -
Vince Becquiot
January 11, 2016 at 7:33 pmIf you created the files in AE, then that might cause a loss of resolution, I would give it a shot and see how they look.
Vince Becquiot
Johan Andreasson
January 11, 2016 at 7:36 pmJust did – and they look equally great.
You really helped me out of a LOT of trouble here since I don’t have much time left for this project.
Thank youThanks
~ Johan
