Activity Forums Adobe Premiere Pro Unwanted “Low resolution”-effect on diagonal edges when encoding H.264
  • Unwanted “Low resolution”-effect on diagonal edges when encoding H.264
    Posted by Johan Andreasson on January 11, 2016 at 5:34 pm
    When exporting this clip from Premiere in H.264 I get some weird “low resolution”-effect on diagonal edges in the film. If I’m using a non-compressing codec like Quicktime Animation theres no distortion at all. I have tried to increase the bitrate but it don’t seem to matter – it’s the same. Also try using Adobe Media Encoder with the exact same results. The problem is the same throughout the while film…
    What am I missing doning wrong?
    ~ Johan
    Johan Andreasson replied 10 years, 8 months ago 2 Members · 16 Replies
  • 16 Replies
  • Vince Becquiot
    January 11, 2016 at 6:24 pm
    Hi Johan,
    Could you post a screenshot of your export settings?
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Johan Andreasson
    January 11, 2016 at 6:29 pm
    Yes, here’s the settings from Adobe Encoder unforunally it’s in Swedish.
    ~ Johan
  • Vince Becquiot
    January 11, 2016 at 6:31 pm
    This looks like the previous image 🙂
    Vince Becquiot
  • Johan Andreasson
    January 11, 2016 at 6:33 pm
    Sorry(!) here it is:
    ~ Johan
  • Vince Becquiot
    January 11, 2016 at 6:39 pm
    My Swedish is a little rusty:-) But it looks like your sequence in upper field first and your export is progressive, so that’s
    most likely where the pixelation is coming from. I would go back to the sequence and change it to progressive and export again, that should fix your issue.
    Let us know how that goes.
    Vince Becquiot
  • Johan Andreasson
    January 11, 2016 at 6:44 pm
    I thought you where right on it, maybe you are, but the settings seem to be set to Progressive…
    ~ Johan
  • Vince Becquiot
    January 11, 2016 at 6:47 pm
    Hmm, are you sure that’s the same sequence? Look at your export screenshot, doesn’t it say upper in your source setting?
    Vince Becquiot
  • Vince Becquiot
    January 11, 2016 at 6:50 pm
    Oh wait, I think I got it, you were exporting the clip directly, not the sequence, correct?
    Vince Becquiot
  • Johan Andreasson
    January 11, 2016 at 7:00 pm
    You’re on to something here. It seem like the source clip that I exported from After effects (which is a uncompressed .mov with codec “Animation) is upper fields because “Övre” means Upper.
    But I can find a field setting in AE?
    ~ Johan
  • Vince Becquiot
    January 11, 2016 at 7:07 pm
    In AE, in your render queue window, click on render settings and under time sampling, make sure that field render is off.
    Vince Becquiot
