Activity › Forums › Apple Motion › Unwanted flicker on Camera move
  • Unwanted flicker on Camera move
    Posted by Parker Bourassa on March 1, 2017 at 4:54 pm
    Hi Creative Cows!
    I’m having a strange problem. I have a simple scene with an .AI file with fixed resolution unchecked. It’s black by default, and I’d like to color in motion. Also, the camera needs to drift slowly. For some reason, when I do this combination of things, the image flickers between light and dare randomly. And the flicker seems to be dependent on the camera’s motion but I don’t see why. The flicker is in the viewport, and in the exported file.
    Here’s the project:
    https://drive.google.com/drive/folders/0BzpypIwWhVapN3BKX294NVgzcUE?usp=sharing
    I’ve tried adding and removing lights (I don’t really need any lights, I’d like flat shading,) and I’ve stripped the scene down to it’s simplest elements. Nothing helps.
    Do you have any why this is happening?
    Thank You!
    Jerry Wise replied 9 years, 6 months ago 2 Members · 7 Replies
  • 7 Replies
  • Jerry Wise
    March 1, 2017 at 5:59 pm
    i tried it out and found no flicker.
  • Parker Bourassa
    March 1, 2017 at 6:01 pm
    Hmm. That’s helpful info, but also sort of infuriating.
    Thanks for taking the time to help!
  • Parker Bourassa
    March 1, 2017 at 6:02 pm
    It seems like others might not have this problem with the file, so here’s what it looks like on export: https://www.youtube.com/watch?v=Jmo7aqXCPi0&feature=youtu.be
  • Jerry Wise
    March 1, 2017 at 6:41 pm
    well i did get the flicker like you did. looking at the animation the buildings were black so i added an ambient light and found no problem. but when i deleted the light and added colorize the problem showed up.
  • Jerry Wise
    March 1, 2017 at 6:46 pm
    i went to Group 1 and changed Position Z to a minus number and the flicker seemed to clear up.
  • Parker Bourassa
    March 1, 2017 at 7:26 pm
    I think that worked for me too.
    Thank you!
    If you don’t mind me asking, how did you know to try that?
    It doesn’t seem to make any sense to me.
  • Jerry Wise
    March 1, 2017 at 9:02 pm
    Back in the days of Autodesk/Smoke i would have issues with the same flickering problem and it was always Z space so i just figured that was the culprit. I hardly ever use Motion so i had to hunt around for the cure.
