Activity Forums Adobe After Effects Unwanted change of position
  • Unwanted change of position
    Posted by Sofia Svensson on February 2, 2010 at 11:44 am
    Very odd thing going on in an animation I’m making.
    Two lines of text are animated in from different horizontal directions. They fly in fast. Keyframe. Slow down and slowly glide forward. Keyframe. And finally speed forward again and dissapear.
    Easy right? It’s AE basics even. So I’m embaressed to say I’ve run into trouble.
    Here’s what happens:
    The text speeds in as it should. Slows down as it should. But instead of slowly going forward, the text sort of bounces back and fourth between the keyframed positions I’ve set. Then they speed off again as they should.
    What’s going on? There’s something wonky going on between the two keyframes and I’ve tried to look at the graph editor for clues but I can’t see anything.
    Appreciate any tips you can give me. 🙂
    Dave Johnson replied 16 years, 7 months ago 3 Members · 3 Replies
  • David Johnson
    February 2, 2010 at 12:43 pm
    Sounds like you might have an extra keyframe or wrong keyframe interpolation for what you’re trying to do. Maybe zoom all the way in on your timeline and make sure you don’t have an extra keyframe between the two you intended to have, then right-click on each of your keyframes to make sure their interpolation is linear (or whatever you want it to be).
  • Sofia Svensson
    February 2, 2010 at 1:53 pm
    Hurrah!! Keyframe Interpolation was set to “Auto Bezier” which caused my problem.
    Thank you so much for your help!!! 🙂
  • Dave Johnson
    February 3, 2010 at 3:14 pm
    Dave makes a very good point with “You don’t have to abandon the use of Auto Bezier if it’s important to the motion”. The various fine-point controls over keyframe behaviors are collectively a strong benefit of doing even basic motion in AE versus most other software. So, if you’re not very familiar with various types of keyframes and keyframe controls, it would probably be beneficial to read up on them.
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7d99a.html
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7d78a.html
