Unwanted audio “pops” at the beginning of audio tracks upon export from Premiere Pro CC 2015
Alright, I have searched tirelessly for a solution and still have nothing. This is a Premiere quirk which I have been experiencing more and more, not sure if it has anything to do with the upgrade to CC 2015.
The problem is that when I export a timeline, occasionally I get audio “pop” noises in the export that were not there when I was watching/listening to it in Premiere. The “pops” I’m referring to only occur very briefly in the rendered video file, and when I refer back to the timeline, the pop noise will always line up at the same time when a new audio clip was starting, even if there was no volume to the given clip when it started in the timeline.
Has anyone else had this problem? I have searched everywhere and cannot find an answer, and it’s wasting a great deal of my team’s time having to preview the video file, see if there are any “pops”, go back into Premiere, attempt to render out the audio from the entire timeline as AIFF and re-import it before re-exporting the whole sequence with this new, pre-rendered audio track. This does not always work the first try either. It is a pain, and it is a time waster, especially because we cannot diagnose the real source of the problem.
I am using Premiere Pro CC 2015, and I have been exporting H.264 Vimeo 1080p 24fps, from a DSLR 1080p 24fps sequence. I have had this issue with 10+ exports at this point, and it seems to be completely random, but the pop sound in the exported video always lines up with where a new audio clip began in the timeline. Not sure if this matters, but it is generally when I have a new audio clip starting from silence, and either volume keyframed up or constant power applied to beginning of clip to fade in the volume.
Thank you in advance to anyone with insights on how to fix this!
