Activity Forums Adobe After Effects unsynchronized footage suggestions?
  • Todd Kopriva
    May 2, 2013 at 9:51 pm
    Make sure that you’ve interpreted the imported image sequence with the correct frame rate.
    After Effects team blog
  • Esteban Bustos
    May 2, 2013 at 9:58 pm
    i checked the frame rate in the render queue it has the same frame rate as the comp (29.97)
  • Esteban Bustos
    May 2, 2013 at 10:00 pm
  • Todd Kopriva
    May 2, 2013 at 10:03 pm
    As I said, check your footage interpretation settings.
  • Esteban Bustos
    May 2, 2013 at 10:24 pm
    i tried interpreting the footage in several ways..nothing changed.. tonight i will render the png sequence again.
    i will reply you then.. thanks for your time!
  • Todd Kopriva
    May 2, 2013 at 10:27 pm
    Show a screenshot of your footage interpretation settings (in the Interpret Footage dialog box). I am nearly certain that you simply need to enter the correct frame rate there and your problem will be solved.
