Activity › Forums › DaVinci Resolve › Unsynch clip to audio
  • Unsynch clip to audio
    Posted by Alex Gat on May 29, 2018 at 1:08 pm
    Hello,
    I have been using the Auto-synch Audio based on Waveform feature, I have a couple of questions :
    – used on camera clips with stereo audio, I added an independent stereo audio which makes a total of 4 tracks which I can see in the clip window question when dragging the clip it only takes the added audio, can’t it take the four tracks ? Or can I even choose which one to take like when taking only audio for example.
    – some synchronisation are just wrong, is there a way to undo the auto-synch ? The actual undo command works great but if used straight away. Perhaps I should ask if I can unsynch the audio afterwards ?
    Thanks for your inputs.
    Alex
    Alex Gat replied 8 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
