Activity Forums Adobe Premiere Pro Unsupported audio rate in file.
  • Unsupported audio rate in file.
    Posted by Shaneksmith on May 28, 2006 at 7:00 am
    Until just this week using an ati all in wonder 9000 pro 9.06 set on dvd, I record to hard drive, then import to adobe, then cut.. no problem. With no update or changing any settings, now for some reason when I import to adobe I get an unsupported audio rate in file message. Ati settings show a 16 bit rate and somewhere I saw something about a 32 bit rate for adobe, I think in custom settings but not 16. this setting creates a mpeg 2 @ 720 x 480 video and 48,000khz (16 bit ) audio. Strange. when I set to video-cd setting in ati–352 x 240 video and 16 bit 44,100 khz. It imports to adobe fine. So why don’t I settle for that? It just bugs me that it worked before with a larger file and I think the final product may be compromised by size somehow. I am using adobe 7.0.
    Thanks, Shane
    Shane Smith
    shaneksmith@triad.rr.com
    Sivakumar replied 19 years, 10 months ago 3 Members · 4 Replies
  • Vince Becquiot
    May 28, 2006 at 8:26 pm
    I would try reinstalling the ATI media software, or even an update if there is one on their website.
    Could be something as simple as a Windows update that messed things up as well, I would check in the Add / Remove section to see if any of those update were installed around the time things started to go awkward.
    Cheers,
    Vince
  • Shaneksmith
    June 1, 2006 at 2:30 am
    Follow up. This may be strange but thought I would report this in case another has a similar problem. Before I had this probelem, I had upgraded to roxio 8 media creator from roxio 7. I kept getting dao errors . So….. I re-installed roxio 7 and low and behold Adobe works again! Go figure, something tweaked the audio synch from a different software. I don’t get it but it works. Now here goes a really lame question: Which is more up to date, Adobe 1.5 or Adobe 7.0? Which do you guys prefer?
    shaneksmith
  • Vince Becquiot
    June 6, 2006 at 2:14 am
    Premiere pro 1.5 is the most up to date. They started the count over and added the word Pro in front of it. It was a huge jump in the quality of the product from Premiere 7.
    2.0 is now the current version, and is also a huge improvement over 1.5
    Cheers,
    Vince
  • Sivakumar
    November 7, 2006 at 6:06 pm
    HELP PLZZ…
    I’M USIN PREMIER 7…
    I HAD SUM M2P FILES…. I RENAMED IT TO MPG N IMPORTED IT N EDITED D MOVIE FOR ALMOS 2 DAYS…..
    BUT 2DAY WEN I OPENED IT, IT SHOWED ME TAT ‘MEDIA IS OFFLINE’ MSG N WEN I TRIED TO IMPORT D SAME FILE AGAIN IT SAID ‘Unsupported audio rate in file.’…
    D ONLY CHANGE I MADE TO MY SYSTEM YESTERDAY WAS DAT, I INSTALLED WINDOWS MEDIA PLAYER 11…..
    PLZZZ HELP ME OUT OF DIS….
