Activity Forums Apple Final Cut Pro Legacy Unrendered video looks better than rendered video
  • Unrendered video looks better than rendered video
    Posted by Nels Mclaughlin on August 21, 2012 at 6:00 pm
    So, weird question here. I’m working with some video that was shot by a co-worker before I started at my current company, but he forgot to white balance before he started shooting, and the background (seamless paper backdrop) is a little over-exposed. Using FCP7, I color-corrected the footage with CC3Way, so that it looks as good as possible, and adjusted the brightness to knock down the exposure a little bit.
    The unrendered video looks as good as I can hope to get it and the background looks like one flat color. But when I render it and play it, you can clearly see that the overexposed part is a different color than the properly exposed part of the background.
    Is there any way that I can export the unrendered portion of the video, or something I can do to get a similar result?
    Nels Mclaughlin replied 14 years ago 1 Member · 2 Replies
  • Nels Mclaughlin
    August 24, 2012 at 12:46 pm
    Sorry – guess that would help.
    Footage and sequence are both DVCPRO HD 720p60, 960×702, 23.98 fps in FCP 7.0.3
  • Nels Mclaughlin
    August 24, 2012 at 1:55 pm
    Make that 960×720, not 702
