Activity › Forums › AJA Video Systems › Unrendered Motion files when duplicating Seq in FCP6
  • Unrendered Motion files when duplicating Seq in FCP6
    Posted by Roland Rudio on July 25, 2007 at 2:12 am
    Hi Guys,
    I just upgraded to FCP6 and I noticed that Motion files rendered in FCP6 becomes unrendered when I duplicate the sequence (this didn’t happen in FCP5). Any thoughts… settings? Thanks in advance!
    Roland
    Jim Watt replied 19 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • John Pale
    July 25, 2007 at 2:34 am
    There have been widespread reports of FCP 6.x losing render files with duplicated sequences, and I have experienced it myself.
    A workaround that has done the job for me is copy/paste into a NEW empty sequence instead of duplicating the sequence.
  • Jeremy Garchow
    July 25, 2007 at 4:23 pm
    John,
    Does that fix it all the time? Is it always reliable or does FCP eventually lose it’s way?
  • John Pale
    July 25, 2007 at 5:33 pm
    Its worked for me on at least a dozen sequences within one project.
    I don’t think that qualifies as extensive testing, but I am think it says something.
    J
  • Jeremy Garchow
    July 25, 2007 at 6:01 pm
    [John Pale] “but I am think it says something.”
    Sure does.
    Thanks.
  • Roland Rudio
    July 26, 2007 at 2:22 am
    Thanks John. When you say copy/paste, you mean copying and pasting the entire sequence?
    Roland
  • John Pale
    July 26, 2007 at 4:12 am
    Yes. Instead of duplicating it, select its entire contents and paste it into the new empty sequence.
    Havent had a problem since I started doing this. Your milage may vary.
  • Jim Watt
    July 28, 2007 at 10:42 pm
    Our work around for this problem which happens frequently is to output the sequence to a QT movie, then it’s indestructable.
    We’ve also had many instances of all our other motion renders being destroyed when we open a motion file with the “open in editor” command from the timeline.
    jw
