Activity › Forums › Apple Final Cut Pro › Unreliable final cut pro X !
Steve Marshall
April 6, 2012 at 1:33 amHello
I have this same issue with X 10.3. This is what happens.You can work for hours and everything seems fine. I realized from trial and error that if you test Command Z (undo) to see if it works then you are ok if it still works. YOU MUST TEST THAT every once and a while otherwise you will never know when it decided to randomly stop saving. This is a terrible glitch that must be fixed.
At some point X stops saving your work but doesn’t show any symptoms. I check every once and a while just like FC7 you would save all he time.
