Activity › Forums › Apple Final Cut Pro Legacy › Unreasonable Render/Export times on MBP?
  • Unreasonable Render/Export times on MBP?
    Posted by Matthew Lamond on May 31, 2011 at 2:25 pm
    Using a early 2009 MacBook Pro with Snow Leopard and the below specs. I’m using Final Cut Pro 6.0.6 as well. I am editing HD 1920 footage, and the footage specs can be found below hardware.
    Anywho, I am getting a 10 minute export time for a 15 second clip I wanted to give someone to preview from my timeline. Their has to be something wrong with that picture. I put my preferred export settings below H264 and MPEG4. I use both, and the mpeg4 is only like 2 minutes faster on export. The whole 2 minute video takes close to 25 minutes to export. Can someone help me determine why this is happening?
    Main Hardware:
    Model Name: MacBook Pro
    Model Identifier: MacBookPro5,2
    Processor Name: Intel Core 2 Duo
    Processor Speed: 3.06 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 6 MB
    Memory: 4 GB
    Bus Speed: 1.07 GHz DDR3
    HDDs: 500GB Internal 7200 RPM. 2x 1TB External firewire 800 HDD. (I tried having the whole project on my internal and then my external. didn’t help either way)
    NVIDIA GeForce 9600M GT:
    Chipset Model: NVIDIA GeForce 9600M GT
    Type: GPU
    Bus: PCIe
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x0647
    Revision ID: 0x00a1
    ROM Revision: 3436
    gMux Version: 1.7.10
    Displays:
    Color LCD:
    Resolution: 1920 x 1200
    Pixel Depth: 32-Bit Color (ARGB8888)
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Built-In: Yes
    DELL E2209W:
    Resolution: 1680 x 1050 @ 60 Hz
    Mirror: Off
    Online: Yes
    Rotation: Supported
    Raw HD 1920×1080 Video source:
    Vid Rate – 29.97
    Frame Size – 1920×1080
    Compressor – Apple ProRes 422
    Data Rate – 18.1 MB/sec
    Pixel Aspect – Square
    Field Dominance – Odd
    Export Settings:
    H264:
    Compression – H.264
    Frame Rate-29.97
    Key Frames-24
    Frame Reordering-YES
    Compressor-Best Quality(Multi-pass)
    Data Rate-Restrict to 6400kbits/sec
    Optimized for-Streaming
    Filter – None
    Size – 1920×1080 (1888×1062)
    Deinterlace – If needed
    Sound – AAC 128kbps
    Prepare for Internet Streaming – Compressed Header
    MPEG4
    Compression – MPEG4
    Frame Rate-29.97
    Key Frames-24
    Frame Reordering-NO
    Compressor-“Best” on slider scale
    Optimized for-NONE
    Filter – None
    Sound – AAC 128kbps
    My whole timeline is rendered, its only 1 main video track with 10 additional video tracks which hold my virtual set, logos, product images, etc. The extra tracks are rarely being used in this production. 2 Audio tracks hold all audio for the movie. I attached a screenshot of my current timeline/working area so ya’ll can see what I see.
    Matthew Lamond replied 15 years, 4 months ago 2 Members · 4 Replies
  • Stephan Walfridsson
    May 31, 2011 at 2:43 pm
    I’ve found that it’s faster to export a selfcontained QT and then use Compressor to transcode.
    That being said, compressing to a high-quality h264 or mpeg4 is a processor intensive task, and a 1920×1080 framesize means a lot of pixels to process.
    Stephan
  • Matthew Lamond
    May 31, 2011 at 2:50 pm
    You know, I thought about that. I have a G5 as well, and with compressor, I utilized both PC’s processors in a node to expedite transcodes. I was worried that the response would just be the fact, my MBP may not be able to handle such HQ files… Let me run a self-contained export and use compressor, I’ll let you know how long it takes. Do these settings look optimal?
    Setting: Current Settings
    Include: Audio & Video
    Markers: None
    Recompress: Unchecked
    Self-Contained: Checked
    May 31, 2011 at 2:55 pm
    That’s the correct settings.
    Stephan
  • Matthew Lamond
    May 31, 2011 at 3:47 pm
    ROFL at the Ed picture. And thanks, FCP has to do the job for my CK as I don’t have any other software for green screening. Just the FCP Suite.
