Activity › Forums › Adobe After Effects › unmult with matrox
  • unmult with matrox
    Posted by Paul Rozon on December 21, 2011 at 5:12 pm
    I am using unmult in conjunction with a lens flair in order to generate a proper alpha channel. Unfortunately when I attempt to export the file as AVI Matrox Uncompressed HD + Alpha, the option for export Alpha and RGB is greyed out. As soon as I delete the unmult the RGB + Alpha becomes active again
    Matrox Mpeg 2 I frame works but the the Matrox Uncompressed does not.
    Anyone with the same issue? Is there something I am doing wrong
    Paul Rozon replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
