Activity › Forums › Adobe After Effects › Unintended Black Spots appearing?
  • Unintended Black Spots appearing?
    Posted by Max Kim on September 17, 2008 at 7:44 pm
    Hi, I’m trying to render a compilation of many smaller animations into a larger final animation.
    However, everytime I attempt to render or view it, I’ve noticed random black pixels appearing in the brighter areas.
    Here’s a screenshot:
    https://img519.imageshack.us/img519/5907/previewvz3.png
    I don’t know why it’s doing this and I’ve verified that the black spots don’t show up in the original – only in the adobe after effects rendering.
    Does anyone know how to fix this?
    Mark replied 18 years ago 3 Members · 2 Replies
  • Chris Wright
    September 17, 2008 at 10:00 pm
    tell us your color management, bits per channel, and output codec settings.
    weird. looks like a wrap around of RGB information so bright it went back to 0.
    try changing project settings to 16bpc from 8bpc and rendering out a single uncompressed frame like png.
    If that doesn’t work, do a quick filter check by adding the effect -Levels and make input 18-235 and output 18-235. 18 being black and 235 being white. Then render out a single frame png again.
  • Mark
    September 18, 2008 at 1:35 pm
    In the intepret footage dialog turn the alpha off and see if it fixes the problem.
    Mark
    Mark Harvey
    Senior Editor
    Le R
