Activity › Forums › Maxon Cinema 4D › Unfolding Cut-Out Doll Approach
  • Unfolding Cut-Out Doll Approach
    Posted by Jay Ingles on November 15, 2012 at 4:24 am
    I need some help determining a good approach to create an extruded line up of cut-out people that hangs like paper. Overall my results are sloppy/undesirable and doesn’t feel like it is unfolding.
    Here is how i am doing it so far:
    1. create multiple cut-outs and individually rotate/scale/position them to unfold
    2. since each shape is different (man/woman/child), tweak PLA over a couple frames so when the “man” shape is revealed from behind the woman shape they have a similar outline
    Questions:
    1. Is there a better approach the unfolding (so it actually unfolds)?
    2. How do i build this knowing i need to add softbody or cloth dynamics so it feels like it is hanging/unfolding naturally? (Its not my first time using cloth/soft body)
    Thanks for your help.
    DOWNLOAD: cutoutforum1.c4d example
    Jay Ingles replied 13 years, 10 months ago 2 Members · 4 Replies
  • Brian Jones
    November 16, 2012 at 3:53 am
    the paper is folded as an accordian fold in these things so it should unfold that way. Here’s a couple tries at it. 4967_cutouttrial.c4d.zip
  • Jay Ingles
    November 18, 2012 at 11:21 pm
    This is great Brian, thanks a lot. The parenting of each level makes a lot of sense…should have thought of that.
    Now that i’ve done that and have attached to a splinewrap, the accordion undesirably fluctuates from the spline as it unfolds.
    Do you have any suggestions on how to seat it against the spline so it is stabilized?
    Thanks again 🙂
    Project file: 4971_accordiansplinewrap.c4d
  • Brian Jones
    November 19, 2012 at 10:26 pm
    in the SplineWrap/Object tab
    – delete the animation track for the Offset, set Offset to 50%
    – down in the Spline area check Fix Bounding Box
  • Jay Ingles
    November 20, 2012 at 3:12 pm
    Thanks, really appreciate your help.
