Activity › Forums › Apple Final Cut Pro Legacy › “unexpected end of file” on firewire drive — how to fix??
  • “unexpected end of file” on firewire drive — how to fix??
    Posted by John Graves on January 1, 2006 at 10:02 pm
    I have a brand new 300 gig firewire drive on my OS9 Mac. WHen I run norton disk doctor, it can’t complete the check and says “unexpected end of file” — on an empty, freshly formatted, brand new drive! Has anyone else encountered this or able to offer a solution?
    I was only able to fill up the drive 66 percent full and then it refused to record more, started dropping frames consistently, and other irritants.
    -John
    John Graves replied 20 years, 9 months ago 4 Members · 5 Replies
  • Kevin Monahan
    January 1, 2006 at 11:26 pm
    Sounds like you need to reformat the drive. Everyone needs to erase the drive between major projects, unfortunately, not many do. And then problems like this happen.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • John Graves
    January 2, 2006 at 12:21 am
    As I stated in my original post, the drive is “freshly formatted” Mac Extended.
    regards
    -John
  • Andy Mees
    January 2, 2006 at 3:26 am
    that is strange, and sorry, I have no idea what the problem might be … still, what made you run disk doctor on a completely blank drive?
    FWIW I seem to remember that Norton Disk Doctor was the cause of many a problem back in the dark days of OS 9.
    What happens when you run Apple Disk First Aid … do you get the same error?
  • Chuck Reti
    January 2, 2006 at 5:08 pm
    [John] “I have a brand new 300 gig firewire drive on my OS9 Mac”
    What vintage/model “OS9 Mac?” Older machines’ logic board ATA bus will not recognize and can’t use drive space above a certain value, around 128GB formatted (137 GB unformatted). This is a hardware, not an OS limitation. If this is the case, you may need to install an IDE/ATA-6 PCI card to access the drive’s full capacity and avoid data corruption.
  • John Graves
    January 3, 2006 at 3:02 am
    This is a G4 dual 500 running OS 9.2.2. I have two other 200 gig drives also from Rocstor and I never had this problem, it was only when I went to 300 gig, and come to think of it, once I went a little bit over 200 gig on the 300 gig drive, this is when the drive started acting up! Over 200 gig I can drag files into the drive, but I can’t record directly to the drive, it gives me I/O errors and dropped frames.
    thanx
    -John
