Activity › Forums › Apple Final Cut Pro Legacy › undo speed changes
  • undo speed changes
    Posted by Anna Lord on April 8, 2009 at 4:04 pm
    Hello, I’d be most greatful if someone could help me.
    I’ve changed the speed of my clips using apple + j . Now I’ve looked through my material and I don’t like it. on some of my clips I’d like to undo the speed change but when I fill in 100% in the box, using the apple + j function again, I get ” Unable to complete command. A conflict occured during a trim operation.”
    How do I go about this?
    Another question: When marking clips sometimes, quite randomly, more clips then the ones I click on gets marked. This is weird since it doesn’t happen all of the time. Is there a function that prevents them from doing so?
    Thank’s!
    Anna
    anakronika
    Anna Lord replied 17 years, 5 months ago 3 Members · 3 Replies
  • Dennis Leppell
    April 8, 2009 at 4:39 pm
    To answer your first question, move the clip to the very end of the timeline, so nothing’s behind it, make your speed change, then move back. A pain? yes. Does it work? Every time.
    Second question….are you holding the shift key?
  • John Pale
    April 8, 2009 at 6:20 pm
    Question 1: Match frame to the original clip. Change the speed to 100% in the Viewer, then edit into the timeline replacing the speed change clip.
    Question 2: This is determined by which tracks have Auto Select turned on. If you don’t know what that means, search the term in FCP Help. You need to understand how it works.
  • Anna Lord
    April 10, 2009 at 5:33 pm
    thank’s so much! I didn’t try this though since this place is so amazing that I already got another answer that worked out for me.
    thank’s again anyway
    anakronika
