Activity Forums Maxon Cinema 4D undo on one object turns off radius and fillets on other objects
  • undo on one object turns off radius and fillets on other objects
    Posted by Sean Platt on August 27, 2017 at 5:44 am
    Can someone tell me why fillet and radius options that were set early on for object(s) turn off when I undo on another object later down the line? Setting the radius and fillet was not the last thing I just set. But they both turn off when I try to undo on another object move. Is this a simple preference option I am missing?I am using C4DR18. Thanks for your help!
    Sean Platt replied 9 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 28, 2017 at 9:48 pm
    Sounds like you may have inadvertently keyframed the radius/fillet parameters? Can happen very easily if you have autokey turned on and forget to switch it off.
  • Sean Platt
    August 29, 2017 at 6:11 am
    Hi Adam, I haven’t keyframed the radius/fillet and the autokey isn’t on. Another thing is when I close the file and open it back up, I have to turn the radius and fillet back on.
