Activity Forums Adobe After Effects Undo mask
  • Posted by Kenn Perkins on September 18, 2018 at 10:10 pm
    I inadvertently touched the comp window with the arrow tool.
    It created a mask I do not want (comp window went black and added a white outlined box which seems to be a mask that can be expanded to reveal the layer I was working on). I can’t figure out how to undo or eliminate the mask.
    I hadn’t saved my project for a while so I don’t want to close/reopen it and lose what I’ve done.
    Any suggestions?
    Walter Soyka replied 8 years ago 2 Members · 4 Replies
  • Walter Soyka
    September 18, 2018 at 10:41 pm
    It sounds like you’ve activated the Region of Interest. There’s a toggle for that in the viewer panel. Check out this image:
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kenn Perkins
    September 18, 2018 at 10:52 pm
    Walter
    Thank you!!
    So simple once you know how to fix it.
  • Kenn Perkins
    September 18, 2018 at 10:55 pm
    Dave
    Thank you for your help. So much faster than trying to find an appropriate tutorial.
    Kenn
  • Walter Soyka
    September 19, 2018 at 12:17 am
    ROI can be a really useful tool, too. If you have a really heavy comp, you can enable the region of interest while you’re working to render only the portion of the frame you want to focus on, instead of having to render the whole frame.
    Walter Soyka
