Activity › Forums › VEGAS Pro › “Undo” hangs
  • “Undo” hangs
    Posted by Kelly Griffin on March 9, 2011 at 10:59 pm
    Is anyone experiencing lockups with “Undo”? I’m getting them almost every time I do anything and try to undo it, either by mouse selection or “Ctrl>Z”, and it’s been happening all along (I’ve only been using Vegas in earnest for the past week or so, but I’ve got a brand new turnkey system and V10.
    Tom Pauncz replied 15 years, 6 months ago 3 Members · 2 Replies
  • John Rofrano
    March 10, 2011 at 12:52 am
    No problems with undo here. Make sure you have the latest version of Vegas Pro 10c.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tom Pauncz
    March 10, 2011 at 7:24 pm
    There is an issue with “undo” and I have a case open with SCS support.
    In my case I use the Decklink Studio ASIO sound driver and the most repeatable scenario is when I have ripple edit “on”, drag a clip and then try to “undo”. It fails every time.
    If I remove the audio from that clip, or change the audio to not use the ASIO driver and repeat the failing scenario, no problem.
    I should also add that the audio sampling rate is set to 48K. If I set it to 44K, no problem with “undo” with the ASIO driver.
    You may have the same issue – what audio driver are you using?
    Cheers for now,
    Tom Pauncz
    (30WEST MEDiA GROUP)
