Activity Forums VEGAS Pro undersample rate
  • undersample rate
    Posted by Roger Bansemer on February 23, 2013 at 6:20 pm
    Is it possible to undersample rate on the track level. I’ve looked at Ultimate S as well but can’t see anything there.
    Roger Bansemer – PaintingAndTravel.com
    John Rofrano replied 13 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    February 24, 2013 at 12:43 pm
    [Roger Bansemer] “Is it possible to undersample rate on the track level.”
    No, undersample is only an event property.
    [Roger Bansemer] ” I’ve looked at Ultimate S as well but can’t see anything there.”
    Here is how you would do it with Ultimate S Pro.
    1. Select all of the events that you want to undersample.
    2. Go to the Visual Effects tab
    3. Press Clear Page button (always a good idea)
    4. Set the Video Media Affected to Selected Tracks and Selected Events
    5. Check Change Event Properties to enable it
    6. Press the Reset button to ignore the switches
    7. Check Undersample rate to enable it an set the rate that you want.
    8. Press Apply
    All of the selected events will be changed to that undersample rate. You can also do this with VASST Property Assistant.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Roger Bansemer
    February 24, 2013 at 1:51 pm
    Thanks John. I was thinking of doing a tilt/pan project using NewBlue rack focus and slowing down the sample rate to give the video an impression of a scale model. St. Augustine would be a good place for that but being higher up like from a building,it works best.
  • John Rofrano
    February 24, 2013 at 11:41 pm
    [Roger Bansemer] ” I was thinking of doing a tilt/pan project using NewBlue rack focus and slowing down the sample rate to give the video an impression of a scale model.”
    Sounds great. I’d love to see it when you’re done.
    ~jr
