uncompressed quick time files to edit in FCP / sequence problem !
Hi hello !
i am working with ntsc QuickTime files that have none compression (codec:none)- this is footage coming from an analog pixel-vision camera, and that is the way it was recorded.
My question is what is the best way to adjust the settings of my sequence in fcp in order to edit this footage. I wonder if i should set my sequence to none compression as well (to match the footage) but i am not sure what sort of consequences would this have – maybe super slow or super mega large project ; or if i should set my sequence to for example DV/DVCPRO-NTSC and always end up rendering my footage into the sequence – and i am not sure what sort of consequences would this have either . . . .Thanks for the help in advance !
F
