Activity Forums Apple Final Cut Pro Legacy uncompressed footage pixellating during cross dissolve…
  • uncompressed footage pixellating during cross dissolve…
    Posted by Dom111 on August 29, 2006 at 12:05 pm
    I’m editing a short sequence using AJA Kona 3 uncompressed pal 10 Bit SD sequence and capture presets, so my rendering should be 10 bit accross the board.
    When I add a cross dissolve between two clips the footage pixellates slightly in the outgoing footage, I can’t think of any possible reason for this.
    Have any of you seen this before?
    Dom
    (I’m running FCP 5.1.1 on a Quad G5 using a SATA II external drive array.)
    Dom111 replied 20 years ago 1 Member · 1 Reply
  • Dom111
    August 29, 2006 at 12:13 pm
    Sorry guys!! Figured it out… Forgot all about dynamic RT for a moment!
