Activity Forums Apple Final Cut Pro Legacy Uncompressed 8 bit 4:2:2 to mpeg 2 (720×486)
  • Uncompressed 8 bit 4:2:2 to mpeg 2 (720×486)
    Posted by Chase Maser on December 2, 2010 at 4:19 pm
    One of are half hour tv shows was picked up by another distributor. We would usually just send them a beta tape with the episode, but they wanted the show as an mpeg2 file. Whenever I use compressor it always turns the frame size from 720×486 to 720×480. Is there any way to keep the original frame size with an mpeg2?
    Chase Maser
    Editor
    http://www.he-tv.com
    Jeremy Garchow replied 15 years, 8 months ago 5 Members · 6 Replies
  • Jeremy Garchow
    December 2, 2010 at 4:23 pm
    Is that what they requested? You should make sure that they want a DVD compliant stream and not a program or transport stream with muxed audio.
  • Alan Okey
    December 2, 2010 at 5:12 pm
    [Jeremy Garchow] “You should make sure that they want a DVD compliant stream and not a program or transport stream with muxed audio.”
    And if they do want a transport stream, get the exact specs. If it has to be 4:2:2 MPEG-2 (which Compressor cannot produce), you’ll need to use something like Telestream Episode. Others have run into this issue when trying to encode content to DG Fastchannel’s specs.
  • Jeremy Garchow
    December 2, 2010 at 5:19 pm
    [Alan Okey] “And if they do want a transport stream, get the exact specs. If it has to be 4:2:2 MPEG-2 (which Compressor cannot produce)”
    Actually, you can these days believe it or not:
    Still Chase, you need to check with the recipient as you have to figure out if there needs to blanking, and perhaps they want something like an IMX50 file.
    Jeremy
  • Rafael Amador
    January 1, 2011 at 8:43 pm
    [Jeremy Garchow] “Actually, you can these days believe it or not:”
    I believe it 🙂
    I’ve to update my self about Compressor.
    Thanks for the info.
    rafael
    http://www.nagavideo.com
  • Alexander Kallas
    January 1, 2011 at 9:05 pm
    [Jeremy Garchow]
    However if you look at your screen-shot, it says
    “YUV 4:2:2 Color encoding (not for DVD use)
    So why use MPEG2?
    Cheers
    Alexander
  • Jeremy Garchow
    January 1, 2011 at 11:09 pm
    To make program or transport streams for broadcast. Not DVD.
