Activity › Forums › Adobe After Effects › unable to use Trapcode Mir plugin
  • unable to use Trapcode Mir plugin
    Posted by Tim Neighbors on February 13, 2017 at 7:27 pm
    I’ve been unable to finish a project for about a month now because my Mir plugin appears to have stopped working in the middle of working on it. I was working in an older CS6 version of AE, had built a mountain range with Mir and was flying around it, passing text, etc., when the problems began. I would get error messages mentioning the Mir plugin, the mountains were reduced to shadowless geometric shapes, and I would get errors any time I tried to play the timeline.
    Since then, I have upgraded to the latest 2017 CC version of AE, reinstalled the trapcode plugins, and still I have these problems. Even starting a new project, when I attempt to use the Mir plugin with basic Animation Presets, I only see a wireframe and I get the error message:
    “After Effects error: MIR: OpenGL error: Could not allocate texFBO (512) (25 :: 241 )”
    Here is a video of this issue along with some other strange issues I’m experiencing with this project open and the MIR layer solo’ed.
    11042_filefeb13102254am.mov.zip
    It can also be viewed here: https://youtu.be/PFpABrYCKRM
    I’ve upgraded to the latest AE version, re-installed the plugin, tried using Adaptive resolution, Draft resolution, Wireframe resolution, “Continuously Rasterize” is not enabled, I’ve used Classic 3D, Ray Trace, etc. I don’t know what else to try. All other Trapcode plugins that I’ve tried seem to work fine, just Mir that has issues. Could this be a failing graphics card?
    Tim Neighbors replied 9 years, 7 months ago 2 Members · 3 Replies
  • Tero Ahlfors
    February 13, 2017 at 8:47 pm
    Have you tried contacting Red Giant’s support?
  • Tim Neighbors
    February 13, 2017 at 9:00 pm
    Yes, I just did that. I’m still waiting for a response from them.
  • Tim Neighbors
    February 14, 2017 at 5:36 pm
    @Dave,
    The plugin install procedure asked me which generation of CS I was installing for and CS6 was an option (which I used before) as well as CC 2017 (which I used this time). …so I assume it is made for these versions. Also, the plugins appear in the software, so doesn’t that mean it is compatible?
    Another note: I’m running 3 monitors. Not sure if that would cause issues with my graphics card (Nvidia Quadro K2200).
