Activity Forums Adobe Premiere Pro unable to upconvert and batch capture with Kona Lhi and Premiere Pro CC? Are they not compatible???
  • unable to upconvert and batch capture with Kona Lhi and Premiere Pro CC? Are they not compatible???
    Posted by Nick Natteau on January 10, 2014 at 1:43 am
    AJA’s web site claims Premiere Pro CC is compatible with the Kona LHi card, but I can’t get the two to work together proper;y. After repeated tries, I uninstalled and reinstalled everything AJA, but still no luck.
    I need to batch capture DV clips from some mini-DV tapes on my Sony MVR035U tape deck.
    But I also need to upconvert them from 480i to 720p60 using my Kona Lhi card. I should be able to do this with Premiere Pro CC. But the PPCC Capture window won’t give me any audio feedback when I select “AJA Movie Capture” in the Capture Settings pull down menu. I only get audio feedback when I enable “DV capture” but then I’m no longer able to upconvert.
    Please see my screen grabs below:
    Nick Natteau replied 12 years, 8 months ago 1 Member · 1 Reply
