Activity › Forums › Apple Final Cut Pro Legacy › Unable to select “drop frame” when blacking a tape in “Edit to Tape”
  • Unable to select “drop frame” when blacking a tape in “Edit to Tape”
    Posted by Ryan Stegman on January 21, 2010 at 10:07 pm
    I’m having a problem blacking a tape with drop-frame time code. I launch “Edit to Tape” and I have a tape in the deck (the problem occurs in both my AJ-HD1400 DVCProHD deck and my Sony PVW-2800 Beta deck). When I press the “black tape” icon at the top of the “Edit to Tape” window, a box appears and says, “Black and Code — Settings.” I hit “OK” and the next box is where you input the starting TC. However, the check box to the right, which you select for drop-frame time code, is grayed out and not selectable.
    I am running FCP7, with Blackmagic Design DeckLink 6.8.3 running. The strange thing is, I ran a dub a week ago and I was able to select drop frame when I blacked the tape. For full disclosure, I was running Blackmagic Design DeckLink 7.3.2, but I had a problem with spitting out a down-convert signal, which is necessary for the weekly project we have. However, I don’t believe that this downgrade is the issue, because our 2 other edit suites are currently running Blackmagic Design DeckLink 7.3.2 and FCP7 (no downgrade) and they also cannot select drop-frame when doing an “Edit to Tape”.
    Is this a problem with FCP7? Did a final cut setting get corrupted?
    Any and all help/input is appreciated!! Thanks!!
    Ryan Stegman replied 16 years, 8 months ago 2 Members · 3 Replies
  • Ryan Stegman
    January 21, 2010 at 11:10 pm
    Problem solved!!!
    I think I’m gonna spray paint the following onto my edit suite wall:
    “WHEN IN DOUBT, TRASH THE PREFERENCE FILES!!!”
    Once I did that, the drop-frame check box became selectable again!!! What a weird bug!
    (FYI, I was editing in DVCProHD 720p59.94, so I knew I should have the ability to layoff a drop-frame tape.)
  • Kevin Monahan
    January 22, 2010 at 6:19 pm
    FYI, corrupt preferences are not a “bug”. Just means your preferences were corrupted.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Ryan Stegman
    January 22, 2010 at 7:53 pm
    Maybe I didn’t use the correct term, “bug”, in the strictest sense, but I just wanted to convey that it was a very strange occurrence, and not something that should happen at all while working in FCP. And it happened for no apparent reason…That’s why I referred to it as a “bug.”
    Again, the problem is fixed now, but has anyone else experienced this particular…hmm, what word should I use if not officially a “bug”…actually, I don’t know what else to call it, since a [software] bug is defined as, “an error, flaw, mistake, failure, or fault in a computer program…that produces an incorrect or unexpected result, or causes it to behave in unintended ways.”, which is what happened in this case!
    Anyways, anyone else run into this?
